Power Steering leak >
Power Steering leak
Power Steering leak
Old 10-14-2017 | 05:10 PM
Default Power Steering leak
I have been chasing a oil leak. I finally realized today it was PS fluid and coming from the cap and not blowby from the breather. Standard GM / Mercruiser style cap. Is there supposed to be a gasket on the cap? Mine does not have one. It locks on tightly it seems, but the canister is wet after a run and it drips onto the alternator and sprays around the engine compartment. I wrapped a paper towel around it and ran for a while. The towel was wet and nothing sprayed in the engine compartment so it is verified to be leaking there. If there is not supposed to be a gasket I will change the cap.
Thanks.
Mach80 is offline
Old 10-14-2017 | 06:08 PM
Just found my answer, My cap does have a gasket as part of the cap. Does not look to be replaceable. Off to get a new cap.
Mach80 is offline
Old 10-15-2017 | 03:36 PM
Sounds like it could be overfilled.
Griff is offline
Old 10-15-2017 | 06:10 PM
Not overfilled. The gasket has a pretty good indention in it from use. It could be 20 years old possibly.
Mach80 is offline
Old 10-15-2017 | 06:43 PM
Some things don't have to be running to wear out...
dereknkathy is offline
