Go Back  Offshoreonly.com > Owners Forum > Donzi
28zx scorpion side to side >
Old 10-15-2017 | 05:10 PM
Default 28zx scorpion side to side
Not sure if this is common or something that can be remedied. When boat starts to get into the mid 70's it starts to get unsettled and starts rocking side to side. At this speed tabs are level and trim is around 5-6. It gets bad enough it's concerning to point I usually get out of the throttle. Props spin in and are 25p mirage plus.
donzi33zx is offline
Old 10-15-2017 | 06:02 PM
I don't quite have the same setup, running 5blade 28p, but I get what you're saying when I power up into the mid 70's quickly and start trimming the drives up I also get the chine walk. If I take it slow from 70 and gradually trim the drives up, 1 level at a time, I have no problem getting 80+. Also helps when the boat is balanced so you aren't playing with the tabs at that speed.
MullenTJ86 is offline
Old 10-15-2017 | 06:24 PM
How do you like the 5 blades?
Old 10-15-2017 | 06:43 PM
They came with the boat, supposedly custom made by Throttle Up, but they are by far the best prop I've ever had on the boat. I've tested Bravo 28's and 30's, about to test labbed 28's, but nothing has compared yet. I'm running faster at lower rpms at every point with the 5, also a higher top end without hitting rev limiter.
I also have whippled 377's, so the 5 blades handle differently for me than they would for a stock 377.
Old 10-16-2017 | 07:32 AM
Google - Chine Walk.
Trim the drive in....and adjust tabs accordingly. Look into the weight distribution of the boat. Verify that the steering system is bled and you have no "slop" in the wheel.
Remember - sometimes you can come out of the throttle and make it disappear but you can NEVER throttle through it..only gets worse.
ShootinRopes35z is offline
Old 10-16-2017 | 07:43 AM
F-2 Speedy's Avatar
Isn't 5-6 on the trim a bit much ??
F-2 Speedy is offline
Old 10-16-2017 | 08:17 AM
5-6 trim isn't unreasonable on the 28zx. I usually run around 4-5 myself, any higher and she starts walking on me unless I'm alone on the lake/river. I suppose I can trim her up to 8-9 and see more speed potentially, but I bought the boat to enjoy, not to bury me 6' under.
Old 09-14-2019 | 04:42 PM
Trim at around 2 boat is rock solid with tabs around 3. After 2.5 trim boat loosens up and at 3 and above any wave when running hard will cause boat to rock and at times will have to let out of the throttle. Just never had a Donzi do this, usually the faster you go the more trim you can give.
Old 09-20-2019 | 10:18 PM
I had a 28zx same thing chine walk above 70
two things worked for me
A small amount of steering input would keep it from happening
or beleive it or not fill the water tank for the transom shower
these boats ride very high out of the water having the extra weight to one side seems to give the boat something to lean against when it’s high out of the water
Donzi Dude is offline
