TRS parts.... drives and more.... OHIO >
Old 10-18-2017 | 05:16 AM
Full Force's Avatar
Default TRS parts.... drives and more.... OHIO
I have many oddball TRS parts here ...Drives, inner and outer transom assembly, gimble ring, helmet, trim cylinders, prop shafts
Low hour Trs left drive, this drive has very little time on it, I was told about 8 hours, shafts look new still, was bottom painted but under that the case looks new, needs stripped and painted.
1000.00 picked up 44138
I have a set of Trs drives here both have 1 tooth missing from lower gear set, so they didn't "blow up" but need gears, uppers good, lower cases and shafts good shape, new gears they will be good to go, both been apart over last couple years so I know the carrier will come out easy, very clean drives just **** paint.
750.00 each picked up 44138 Ohio
Trim cylinders 150.00 each literally like new but painted red
outer transom assembly no ring or helmet, was chromed at one point 100.00
Prop shafts right and left 100.00 each
Inner plates 50.00 each
Outer parts ask as needed i will price them
Pm me needs
Attached Thumbnails TRS parts.... drives and more.... OHIO-trs-drives1.jpg   TRS parts.... drives and more.... OHIO-trs-drives2.jpg   TRS parts.... drives and more.... OHIO-trs2.jpg
TRS parts.... drives and more.... OHIO-trs4.jpg   TRS parts.... drives and more.... OHIO-trs-left-.jpg   TRS parts.... drives and more.... OHIO-trs-left1.jpg
TRS parts.... drives and more.... OHIO-trsleft2.jpg   TRS parts.... drives and more.... OHIO-trs1.jpg   TRS parts.... drives and more.... OHIO-trs5.jpg
Full Force is offline
Old 10-23-2017 | 09:52 AM
Full Force's Avatar
ttt
Old 11-13-2017 | 08:10 PM
Full Force's Avatar
ttt
Old 12-04-2017 | 08:52 PM
Full Force's Avatar
ttt
Old 01-07-2018 | 07:23 AM
Full Force's Avatar
ttt
