Holley HP EFI display >
Old 10-26-2017 | 07:55 AM
Default Holley HP EFI display
Finally pulling the Trigger on a Holley HP EFI for my blower motor...
Is anyone using the 3.5" LCD touch screen ?
Thinking of mounting it in place of my speedometer that doesn't work anyway..
Is it daylight view able ? I understand it's not waterproof .. I ususally get stuff covered if it's raining out...
Also, Has anyone set up a GPS input to datalog speed ?
Looking at the Autometer GPS unit...
From what I'm reading, it looks like it may have the correct output signal for the Holley unit..
THANKS !
Doug
Boatally Insane is offline
Old 11-19-2017 | 09:21 PM
I'm not using a Holley screen, but I do know that Holley does not talk with many things other than Holley and racepack. I had kid turbo build some gateways to convert to nmea2000 in order to have the engines show up on my chartplotters.
delsol is offline
Old 11-20-2017 | 07:42 AM
Holley sells a gps input.
kvogt is offline
Old 11-20-2017 | 07:47 AM
F-2 Speedy's Avatar
does this hook to the laptop interface port ??
F-2 Speedy is offline
Old 11-20-2017 | 07:53 AM
usb plug that plugs into any of the Holley digital dashes
kvogt is offline
Old 11-20-2017 | 07:54 AM
https://www.holley.com/products/fuel.../parts/554-140
delsol is offline
Old 11-22-2017 | 12:57 PM
IF you have a $700 digital dash... trying to NOT spend that much on the display..
Doug
Old 11-22-2017 | 01:23 PM
Doug
Huh. You didn’t seem new to boating. Lol
Baja Rooster is offline
Old 11-22-2017 | 01:53 PM
I have the Holley everything on mine, except that one. Its a small display, I would recommend the DASH but yes its more money. You can tune on the Dash now, and you can add the GPS puck.
launchpad475 is offline
Old 11-22-2017 | 01:56 PM
I run the 7.5" display along with the GPS. It works great. It can do everything including prop slip.(have to set up a math channel for that) has data logging and play back.
The issue I would see with small ones is seening them in daylight as even with the my 7.5" it can be hard to read at times.
Now if only I could find away to have my trim indicator into it I could get rid of all my gauges.
Mike
turbom700 is offline
