Oil ratio for winterizing?
way to much - Volvo Penta did a lot of testing and 50 to 1 was best without alot of deposit formation and spark plug fouling. All 2 strokes outboards are recommended at 50 to 1 as well. Never seen a 2 stroke outboard corrode from the inside out on inland waters and very few and I mean very few boat owners winterize their 2 stroke outboards nor have shops winterize them either.
When mixing the oil ratio in the water sep fuel filter only --- one will never get a proper winterized mix because fresh gas is continuously entering the filter through out the whole capacity as soon as the engine is stated.
The lowest I would go would be 35 to 1 especially if it was a 496.
Good question. I made it through years with doing nothing then eventually went to spray fogging oil at a high idle through the carb til it snuffed the engine out. Never had any problems either way.
If carbed, I just dump 10W-30 down the carb until it starts smoking then keep pouring until the engine dies. This outs a heavy does of oil everywhere. In the spring when I fire it up, the engine will smoke for 5 minutes at idle but it eventually clears up.
