Crane cams and roller lifters (retrofit)
I have 2 crane hydraulic roller cams here from mark4 Merlin blocks, came from running engines few ma...rks on cams but not issues as they are used. One looks older then the other but not sure to be honest. 200.00 per cam
Also 2 sets of crane hydraulic roller retrofit lifters. 400.00 per set
Parts I was told have approx 60 hours I didn't build them so that's all I know.
stock gen 6 stock uses dog bone retainers, but no problem running tie bar style, gen 6 also uses a retainer and step nose cam in stock form, but you may be able to run a cam button and use these, dont know for sure ??
I couldn't get dog bone out my mouth. Lol... You might be right on the cam working with the thrust button. Bolt patterns are different I think btwn the two which might limit double roller and or finding correct cover however I'm really not sure and don't wanna screw up any potential sale. Now I'm curious.
the 741 flat nose cam won't work in the gen 6 block, the cam is recessed to far back in the block and then you can't bolt the timing gear on, the gen 6 has a smaller bolt pattern also. that's why I bought a stage 4 from Teague.
