SSM #4 drives and Gimbals/transom assemblies
$10, 000
1. 50 ratio .Always fresh water .Both drives gone thru at Collabellas in 2013, new lower gears and polyshaft , RH gone thru lower and brand new prop shaft in 2017 @ Speedmaster inc. No leaks, oil clean, no issues, no salt junk. Gimbal assemblies in great shape.
LH has 26 spline big shaft RH has a 19 spline new shaft ( I use the 26 spline Arneson adapter)
Will sell a set or 17.5x33 props for $1500 with drives.
^^^^ This receipt does not include shaft and new lower gears which came from different vendor
Perfect for a TRS conversion...
