#5 lower case the same as a #4? >
Old 11-09-2017 | 07:43 PM
Default #5 lower case the same as a #4?
interchangeable?
ICDEDPPL is offline
Old 11-09-2017 | 08:42 PM
Yes
class6 is offline
Old 11-09-2017 | 08:52 PM
I don't think you can put #4 gears, shafts and bearings in a #5 case or vise versa, can you? I think to do the swap, the lower would need to be complete with the correct internals in it.
endeavour32 is offline
Old 11-09-2017 | 09:14 PM
Complete will bolt up.
class6 is offline
Old 11-10-2017 | 05:15 AM
Good question and I'd like to know the answer as well. As for a complete lower swap I believe one potential issue could be the polygon vertical shaft in a SSM IV, not sure the V used a polygon shaft.
ezrizer is offline
Old 11-10-2017 | 07:03 AM
So what is the weak area of the #4? The upper or lower? I know that Gary sells straight cut gears for the #4 that will make it equal to, or close to as strong as a #5.
Old 11-10-2017 | 12:32 PM
A SSM4 is a shortened SSM3. A SSM5 is a shortened SSM3A. I believe the main difference is 3A and 5 have bigger shafts.
Griff is offline
Old 11-10-2017 | 04:30 PM
The gears are better in the 5 vs 4 and the bearings are bigger as well. Other than the prop shaft, I don't think there is much difference in the actual shaft size in 4 vs 5. They are cut different. Splined (5) vs polygon (4), but as far as I know, the overall diameter is the same.
Old 11-10-2017 | 04:58 PM
Finally got a hold of Collabella ,.. the 2 are not interchangeable.
The 5 lower has bigger stuff in it..
ICDEDPPL is offline
Old 11-11-2017 | 05:51 AM
That makes sense 'cause I researched putting 5 lower intervals in a 4 housing and that wasn't an option.
ezrizer is offline
