496 stroker 454 cam choice... 731 vs 791
got a motor build underway... and all down to cam selection..
gen 6 454 roller block
496 stroker
305 dart top end setup
looking at the 731 or 791.... crane roller for a nice 5200 RPM peak rpm setup
would the 114 lobe center be better with wet exhaust or do the if it aint broke dont fix it of the 731 setup that is a nice KISS setup for that size motor...
going into a 22 ft checkmate vision
had a 496 with 761 in it before some dousche stole the engine in a storage unit prior to my buying the boat and it was about perfect for the boat HP and use wise... but not looking to be as aggressive because area i can boat is MUCH SHORTER in distances
will be GIL manifolds and later when $$$ allows headers
or would it be more worth the $$$ to get a firing order swap grind of either of them
ULTIMATE RELIABILITY is goal. not over all peak tq and hp... and smoother idle for ease of slow speed in tight quarters is the goals
everything says 791 and the 114 lobe center is the winner but you never hear of anyone using it...
496 stroker
that's not the 791.... the 791 is IDENTICAL to the 731 but cut on a 114 LSA
Cam Style: Hydraulic roller tappet Basic Operating RPM Range: 1,800-5,800
Intake Duration at 050 inch Lift: 226
Exhaust Duration at 050 inch Lift: 236
Duration at 050 inch Lift: 226 int./236 exh.
Advertised Intake Duration: 288
Advertised Exhaust Duration: 298
Advertised Duration: 288 int./298 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.587 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.610 in.
Valve Lift with Factory Rocker Arm Ratio: 0.587 int./0.610 exh.
Lobe Separation (degrees): 114
Computer-Controlled Compatible: Yes
Grind Number: HR-226/345-2S-14 IG
GETRDUNN you looked at the 691... WAY TO MUCH CAM for a 496 in a boat lol
731's and 741'shave been fine with stainless marine exhausts and Diamond Marine's KE's. on 454's -540's. I would not get Gill's unless the HP500 style tails that go way up before going back down.
