Diffrent  seawaterpumps on Bravo Applications??? >
Old 11-19-2017 | 06:27 AM
Default Diffrent seawaterpumps on Bravo Applications???
Hello
I look for some infos about Mercuiser Seawaterpumps for older Style.I have an new Pump complet with pulley for V belts partnummer
46-807151A8 (merc standart engines)
I check all partnummbers separate with seawaterpump number 807151A31 (new 46-8M0084270)(merc racing engines)
Shaft and other parts have all same nummer.but i found no housing nummber for the Racing engine pump as this house is not sold separate!But it looks exact same .Shaft and so also same part!
My meaning is the big nummber from standart engine is for a complett pump with pulley and the Racing engines have same pumps,only without the Pulley as there must be a Hub mount on the shaft! Old partnummers on both pumps are near same,only other ends! 807151 and then A8 and Rave with A31!
All coments are recommed! Thanks!
Michael
Brembofreak is offline
