1986 sonic part out 502 gen 6 >
Old 11-20-2017 | 10:33 PM
Sick Stinger's Avatar
Brotherhood #1
Default 1986 sonic part out 502 gen 6
1986 38' Sonic part out
Gen 6 502s with dominator carbs , weind intakes, scorpion rockers, one piece push rods. Motors run. Hours unknown - $4500 each, $5200 with exhaust each $8000 pair, $9000 pair with exhaust
Gen 2 stainless marine exhaust $1200 each set $2000 for both sets
TRs drives - lowers are cracked but hold oil, uppers are good $800 each or $1400 pair
72c Borg Warner trans $500 each $800 pair
Kplanes $750 for set
Transom assembly tight $500
Transom assembly loose $200
Pair for $600
4" Tips $150 pair $250 both sets
Zieger full hydraulic steering $2200
Morris trim on throttle with cables $275
Gaffrig gauges $250
Indicators $400
A/C heat set up $1200
Generator $800
Triple axel aluminum trailer - new tires, springs and shackles (recommend 36') $3400 - needs winch post
Sick Stinger is offline
Old 11-28-2017 | 08:10 AM
Brotherhood #1
Controls sold
any one needs wants the arc I'm taking it off tonight with a saw or unbolt if needed
Old 11-28-2017 | 10:03 AM
F-2 Speedy's Avatar
are these 088 heads on the 502
F-2 Speedy is offline
Old 11-28-2017 | 10:41 AM
Brotherhood #1
Has 088 heads on it yes and I have 4 sets in the garage.
Old 11-28-2017 | 11:41 AM
Brotherhood #1
Motor pic
Old 12-05-2017 | 06:45 PM
Default Bell housing
Rigging a twin engine chev big block with engines forward looking for bellhousings,drive shafts,rear carrier brkt for a bravo drive set up.
kevinlafleur is offline
