Exhaust system question >
Old 11-23-2017 | 01:08 PM
Default Exhaust system question
At what point do you worry about have a water reversion problem in your exhaust system. Stellings headers and tail pipes. Water enters the tail pipes about 16 inches away from the header were it meets the tail pipe.
Single cat is offline
Old 11-23-2017 | 01:12 PM
It depends on how much overlap the cam has
Griff is offline
Old 11-23-2017 | 01:22 PM
Default cam
It has a over lap of 90.0 degrees
Old 11-23-2017 | 02:06 PM
I would go back and check that number
class6 is offline
Old 11-23-2017 | 02:09 PM
Default Cam
That's what it comes up to be in the calculation online. It's 264/272 @ .050 on 114 LSA. It said to put it in as advertised duration
Old 11-23-2017 | 07:41 PM
SB
40* overlap at .050"
No way to find overlap at seat without those #'s.
SB is offline
Old 11-23-2017 | 08:15 PM
vintage chromoly's Avatar
That's some big duration for a marine cam.
high compression and race fuel?
vintage chromoly is offline
Old 11-24-2017 | 11:59 AM
Default Cam
OK got my cam card out today. Is there a particular number to look for when it comes to reversion
Old 11-24-2017 | 12:46 PM
40* is a lot of overlap and likely to revert water with wet exhaust. Most marine cams are 20* or less.
It will also depend on how many cubic inches you have. A cam that reverts in a 502 might not in a 540 and will be mild for a 572.
Camshaft Overlap Calculator - Wallace Racing
Griff is offline
Old 11-24-2017 | 01:08 PM
Default cam
Thanks for the input. Not looking to change cams or anything just trying to avoid a problem in advance. Was not wanting to have to change my tail pipes because they have built in mufflers but it looks like I don't have a choice all good.
