600 ci NA build >
600 ci NA build
600 ci NA build
Old 12-06-2017 | 10:14 AM
Default 600 ci NA build
I see it seems like a lot of people on here are in the process of building or have built bigger CI NA combos. We are in the process as well of building 2 600 ci NA combos for our boat. Just curious of what a lot of guys combos are and what kind of power they made.
Single cat is offline
Old 12-06-2017 | 12:04 PM
Default Build
Ours will be 600 ci conventional style cylinder head, 4 stage dry sump,cast intake single throttle body in EFI. We are looking to make between 900 to 950.
Old 12-06-2017 | 12:15 PM
What drives do you plan to use?
BenPerfected is offline
Old 12-06-2017 | 12:17 PM
We have #6 drives.
Old 12-06-2017 | 12:42 PM
Pump Gas??!! if so..950 seems a bit of a "stretch" to me??
TAStevens is offline
Old 12-06-2017 | 02:12 PM
We run mixed pump gas. Comes out to be around 98 octane
Old 12-06-2017 | 03:15 PM
What bore and stroke combination will you use and the targeted max RPM?
Old 12-06-2017 | 04:36 PM
They will be 4.605 bore and 4.500 stroke. For those short blast we will turn it up to 7400 ish. We have a 32ft Skater so it accelerates extremely well.
Old 12-06-2017 | 04:47 PM
F-2 Speedy's Avatar
Off the shelf cam or custom................its a joke.........but are you going to run a large journal cam or std. sounds like a nice build
F-2 Speedy is offline
Old 12-06-2017 | 04:49 PM
Big base circle deal with roller cam bearings. Jesel 904 lifters with the .820 wheel.
