Water temp ad oil pressure sending units for dual station or twin engine?
When they say dual station do they mean twin engine, or Im thinking two sets of gauges monitoring one engine? makes sense if they are half the resistance for dual station because it is additive thats its when you have two sets of gauges monitoring the same engine
Im looking for sending units that are same ranges as MPI 502 stuff but in 1/8 NPT not the 3/8 or 1/2 that is more commonly found. Alot easier because I can put them in metric reducer bushings and bolt right into the LS stuff
https://www.marinepartssource.com/pr...=Sending+Units
http://www.tadiesels.com/assets/docs...ance_Value.pdf
https://fariabeede.com/site_manuals/IS0085d.pdf
The North American standard for all gauges is 240-33 ohms (Empty - Full or Cold - Hot) The same scale (240-33 ohms) is used for 0-80 psi or 0-100 psi gauge, or any other type electrical gauge. The gauges and senders are gauges are matched to the scale being used
Thats not the temp scale for water at least, Id assume oil would use the same
