Compression Check
make sure your kill switch works - 2 ways to test it is pull it while engine running and then return ignition key to off - then try to restart engine and listen for the fuel pump to come on making sure about that one. . Put kill switch back on and restart your start your engine.
you can always pull the fuses as well
