Large list of parts for sale >
Old 01-08-2018 | 12:39 PM
Sick Stinger's Avatar
Brotherhood #1
Default Large list of parts for sale
I will get pics of parts wanted.
Mostly everything I have for sale.
(4) 088 heads per set $650
- 2 sets off of 420s with cracked blocks
- 2 sets off of 502s with cracked blocks
(1) 30" Tie bar $100
(1) 32 1/4" Tie Bar TRS $100
(1) 33" heim joint tie bar $100
(1) 34" TRS tie bar $100
(1) 35 1/4 TRS tie bar $100
(3) 4" angled tips per set $150
(2) 4" Gil mufflers per set $175
(1) 4" shot gun mufflers per set - missing actuator on one $150
(1) 4" Straight tips per set - flanges cut $75
(2) 515 gen 6- GM
Intakes ho500 carbs scorpion rockers, one piece push rods. New lifters , Motors run. Hours unknown. $4500 each
(1) 468 - 420 Hi Perf block , crane magnum rockers, crane cam, 049 heads, speed pro Pistons , 10 qts pan, weind intake, imco aluminum slant covers edlebrock carb new fuel filter 170 hours on meter. $4000
(2) 502 72 hours on refit
have dart intakes, heads, Holley carbs, good rockers 1 piece push rods.
Make 500 HP , have build and dyno sheets. $5200 each
(1) 510 gen 6 450 HP�40 over gen 6 motor�JE pistons �088 heads�502/415 cam�Dart intake�Holley carb �$5200
(2) 540 Merlin block, Merlin heads, 9.8 decks, Holley hp carb. Less than 100hrs. Make 550hp. $7,500 each
(1) 454 MPI motor
sucked water from manifolds, motor runs - low compression
890 hours $2200
(2) 502 MPI motors - 1 running $5200. 1 for parts/repair, turns over $3500
(1) Merc 350 mag motor. Out of a cruiser.
Had a rotter transom motor was pulled.
Boat had 400 hours. Motor is a reman guessing 200 hours but not 100% on it.
Motor is all there less and alternator
Bell and coupler also included. $2000
(1) 454 330 217 hours, fresh water $2800
(1) 502 250 hour $4500
(3) 502 need rebuild $2000 each
(2) Roller Rockers & Push Rods�420's $125
(1) SBC Crane rollers $100
(1) McLeod power foot rests - pair $1200
(2) 72c Borg Warner transmission $500 each
(1) 990 heads per set $650
(1) A/C heat set up $1200
(1) Alpha transom assembly $350
(3) BBC valve covers with rubber gaskets $50 each set
(5) Bravo 1 drive $1800 each
(1) Bravo 1 drive $1300
(2) Seacore Bravo 1 drive�Less than 5 hours on drive - new end of 2016 season $2800 each
(3) TRs counter rotation drive - (1) lower is cracked but holds oil, upper is good
$800 (2) non cracked $1000 each
(3) TRS standard drive (1) lower leaks oil $800, (2) no issues $1000 each
(3) TRS transom assembly $800 each
(1) TRS transom assembly- loose for parts only $500
(1) HD Bravo transom assembly $1500
(2) Bravo transom assembly $800 each
(1) Bravo transom assembly �Loose, parts only $500
(1) MR drive $300
(8) Trim pumps $150 each
(5) Fuel filter housing $50 each
(2) Gen 6 flywheel $125 each
(2) Gil Bravo dry exhaust $1200 each set
(1) Gil TRS long dry exhaust $1400 set
(1) Imco risers $600 set
(2) KE hurricane exhaust per set $1300
(2) Gil Silent choice riser $500 each set
(2) Stainless Marine TRS Exhaust $1200 each
(2) Gen 2 stainless marine exhaust $1200 each
(1) Set of imco power flow plus. Bravo app
Clean, missing one jumper hose from manifold $1200
(1) Hynautic steering - Hynautic rams, helm, thru hull and back cap (no lines or wheel) $1600
(1) Indicators $400
(1) 280s kplane $750
(1) LH 21P Mirage Prop $150
(1) LH 23P Thunderbolt Prop $100
(1) RH 17P Aluminum Prop $75
(1) RH 21P Mirage Prop $150
(1) Morris trim on throttle with cables $275
(1) K throttles with cables $230
(2) MSD Coil $20 each
(2) MSD box $50 each
(3) Offshore motor mounts $250 each set
(1) Quicksilver generator 270 hours $800
(2) 8" pop up cleats $50 each
(1) Triple axel aluminum trailer - new tires, springs and shackles (recommend 36') - needs winch post $3400
(2) twin water dump $70
(1) single water dump $40
(1) Zieger full hydraulic steering $2000
(1) Standard Horizon GPS 155c $200
(1) Garmin 440s GPS $275
(1) Garmin 172c GPS $175
(2) Beauty ring $50 per set
(2) 2 group pulley $50 each
(2) 3 group water pump pulley $70 each
(1) Rex Marine gauge set $250
(1) Chrome Livorsi gauges $200
(6) 3 grove aluminum crank pulley $70 each
(3) Distributors $200 each
(2) Gen series sea water pump $300 each
(4) Mark series sea water pump $150 each
(4) Bravo coupler $150 each
(2) HD Bravo coupler (candlestick) $275 each
(2) Aluminum Moroso puke tank $50 each
(9) Bravo shift bracket $40 each
(1) Lg reservoir bottle $75
(4) Sm reservoir bottle $50 each
(1) Gaffrig gauge set for twins $450
(2) White illuminated rocker switch panel $50 each
(1) 6 black rocker switch panel $30
(1) Black illuminated master rocker switch panel $75
(1) HP500 oil cooler $275
(1) Fuel shut off valve $100
(2) Hawk 4150 525 SC flame arrestor with original decals $200 each
(8) TRS Bell housing $100 each
(4) Bravo bell housing $125 each
(2) 6" Richie compass $250 each
(1) 3" Richie compass $120
(2) Hp torque plate $175 each
(2) HD torque plate $250 each
(3) STD torque plate $100 each
(1) Guest Sportsman Power Center Battey Charger $300
(1) Drop out bolsters $1200
(2) 3 position bolsters $1300 each set
(5) Sit down seats $400 each
Sick Stinger is offline
Old 01-08-2018 | 05:06 PM
Default Ziegler full hydraulic steering
I may be interested in the steering. Is it a complete set up for dual drives? What’s included helm to drives?
Frey3581 is offline
Old 01-08-2018 | 05:21 PM
F-2 Speedy's Avatar
Can I see the puke tanks Sir..........you have my cell to text pics
F-2 Speedy is offline
Old 01-08-2018 | 05:25 PM
hblair's Avatar
I need 2 bellhousings with the starter in the bottom position, interested in some bolsters, and a nice 6" compass.
hblair is offline
Old 01-08-2018 | 05:36 PM
Can I get a pic of the Indicators please 4195691894
justintocars is offline
Old 01-08-2018 | 05:41 PM
I want to give a big thumbs up to Mike. Great guy to deal with!
class6 is offline
Old 01-08-2018 | 06:07 PM
Brotherhood #1
Steering- compete set up for TRS , I can get bravo wing plates for a few hundred more
i have plenty of bravo bell housings , can send a pic compass and bolsters.
I can send over pics of indicator parts when I hit home
class 6 thanks I try my best.
And thanks everyone else also for interest.
Old 01-09-2018 | 11:10 AM
I need a set of (4) 4" angle cut exhaust tips. Pics to 901-491-4500 when you get a chance.
payuppsucker is offline
Old 01-09-2018 | 12:17 PM
I'll get in line behind Frey3581 for a look at the Zieger Steering and Bravo wing plates. Pics to 7045079427. Thanks!
standingBuffalo is offline
Old 01-09-2018 | 12:57 PM
Brotherhood #1
Steering
