Which Ram Size For External Hydraulic Steering?
I am looking at buying a Mayfair hydraulic add on set for my 2005 Baja 25 Outlaw Bravo 1. They have two different options available.
Option 1
Part # 137-9414
(Ram Mounting Location is 9" from the side of the Gimbal Housing) (7” stroke ram)
Mayfair Single Bravo/Dual Ram Add-On Hydraulic Steering Kit - CP Performance
Option 2
Part # 137-9412
(Ram Mounting Location is 17-3/4" from the side of the Gimbal Housing) (9” stroke ram)
I don’t see any reason why either one would work, which one is better? Any reason I should choose one over the other? Would love to hear from anyone who has added a Mayfair set on their boat.
Thanks!
Option 1
Part # 137-9414
Option 2
Part # 137-9412
Thanks!
Convincor has the answer, just a comment
I like the looks of the dual rams but IMO you could get rid of all the add on stuff and install full single cylinder 9 or 17 cylinder for 100 more. No more PS pump and steering cylinder. Thinking bout installing one of these my self,
Mayfair Single Bravo/Single Ram Full Hydraulic Steering Kit - CP Performance
But may go dual just can not get past another grand for another cylinder
That said, I'm still working to get to 50MPH so I don't need it
Get the 9" stroke rams especially for a single engine boat. The more you are able turn the drive for docking, the better.
I've had add on and full hyd. I would never go with and add on system again.
Something else to consider..
If you go with the full single system now, you could always add a 2nd ram in the future. Will require a different helm but all the plumbing will be there with the exception of hooking in the second ram.
BTW, I'll never have cable steering again..
Addressing the 2 lines I highlighted and colored. You still use a PS pump with that system and I believe that full hydraulic steering is one of the best upgrades you can do to a boat regardless of speed. The difference of cruising between 35-50 is effortless when you have hydraulic steering. Even the addition of Drew Marine Sidewinders is a good upgrade.
Agree, full hydraulic is the way to go, and with dumping 50K in a 20K boat already, it may be a mod in the future still after I get everything else sorted out.
Typical Full Hydraulic Steering diagrams. (Scroll down for different applications) http://www.everettperformance.com/PD...se_Drawing.pdf
Thanks!!
