low compression ?????
Old 10-19-2002 | 05:25 PM
Hot Boat's Avatar
Team Dysfunctional
Default low compression ?????
I have only 115 Psi in the # 2 cylinder. If I put my hand over the exhaust port it will suck my hand in . My fist guess was a bad valve. I then pressureised the cylender with air to here where the leak was and I didnt here a thing.
What might this be?????????
Hot Boat is offline
Old 10-19-2002 | 05:38 PM
Oh BOY! Call me later when you get teh chance. Father in hospital with heart trouble dog in hospital sick, wife sick to!
Shane is offline
Old 10-19-2002 | 06:40 PM
gmhdfan's Avatar
Chevy-Harley fan
Is the intake valve opening?
gmhdfan is offline
Old 10-19-2002 | 07:47 PM
Audiofn's Avatar
Charter Member #232
Shane sorry to hear about your Father Hope it is not to serious. Hotboat I would as has been said check the valves to make sure it is opening. Also I assume it was not coming out the crank case?.
Jon
Put your best foot forward!
Audiofn is offline
Old 10-20-2002 | 07:37 AM
Paul, I am forced to sell my boat after last weekends events with you !!!!! May I suggest that you do the same.
YOU
ARE
A
JINKS
BTW, How is the whole in the side of your boat doing ??
Bob
otis311 is offline
Old 10-20-2002 | 09:10 AM
Hot Boat's Avatar
Team Dysfunctional
well I seem to be sure that I suked a valve. at least I found it befor it was to late. I'll pull the heads off later today and look at the dammage. I just hope everything else is okay.
Bob what happened????? call my cell after 11:00 I'll be helping Chris pull his drive. The hole is fine. Its on the side of the transum. If it was 3" forward it would of went threw the boat.
Hot Boat is offline
Old 10-20-2002 | 07:53 PM
Low compression, dropped valve and a hole in the transom!
What is going on here?
Dave
dckrafft is offline
Old 10-20-2002 | 08:20 PM
tripps's Avatar
Default locomp
het hotboat ,if you r lucky u can just put a valve in itand b lucky cause u got no time on it tripps
tripps is offline
Old 10-20-2002 | 08:25 PM
Audiofn's Avatar
Charter Member #232
If it was a valve wouldn't you hear all the air rushing out?
Jon
Audiofn is offline
Old 10-20-2002 | 08:38 PM
Hot Boat's Avatar
Team Dysfunctional
Dave last weekend when everyone was up in Lake George Chris, bob and I had our boats close together out in the lake just sitting there bull ****ing . there wasn't any boats in sight but out of no where I spot a huge wave heading towards us. We all pushed our boats away as far as possible but when the wave came in it was much larger than we thought and Bobs boat was thrown right in to mine. his K plane almost went threw the hull. It was a freak thing and no ones fault. Its nothing that cant be fixed.
How is the house coming along?????. We all get together for dinner every couple of weeks for prime rib at this place off 94. Give me a shout one day if you would like to join us...
paul
Hot Boat is offline
