info on my motor >
info on my motor
info on my motor
Old 01-24-2018 | 04:35 PM
Default info on my motor
I have a 1995 boat 502 mpi mag block cast #10237300 that makes it a gen 6 stamped vin # T11419HJ could be T11119HJ can't seem to find any info from the vin any help would be great thanks . there is no merc plate on the block .
float n nutz is offline
Old 01-25-2018 | 12:57 PM
It is probably a 502EFI with a VST system.
That is not a Merc ID # so I doubt you'll find anything with that number.
Check www.mercruiserparts.com
Griff is offline
Old 01-25-2018 | 01:12 PM
Motor may have been replaced from the casting number.
10237300...502.......96-up...4-bolt, Gen.VI, 4.466" bore
AllDodge is offline
Old 01-25-2018 | 02:47 PM
if the link works https://www.perfprotech.com/blog/boa...marine-engines it says that it is a 1999 502 Mag MPI
compedgemarine is offline
