Drive spacer install help pls
Ok, ran into another problem when I went to start bolting everything back up. I guess it is called the 'collar bushing' (That is what I see when I look up the part number) -- I don't see how it would fit with the spacer? There is a recessed area in the upper that part of the bushing fits into, but it would stick out too much for the spacer to fit flush. There is a recessed area in the lower that it would also fit what appears to be halfway into, but still not allowing the spacer to fit flush their either. What gives?
I don't know what part you a talking about. Post the Merc part number
Genuine Mercury & Mercruiser parts. GEAR HOUSING(BRAVO ONE)
Genuine Mercury & Mercruiser parts. DRIVESHAFT HOUSING AND DRIVE GEARS(STANDARD)
