Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Duratec high gloss gelcoat additive primer >
Old 01-30-2018 | 07:23 PM
Default Duratec high gloss gelcoat additive primer
Hi
is there any other primer than duratec i can use before shooting my gelcoat mix with duratec clear hi-gloss gelcoat additive on my boat ?
thanks
Perf langlais is offline
Old 01-30-2018 | 10:43 PM
glassdave's Avatar
Neno the mind boggler
Duratecs primers really are the way to go, their pretty cost affective. My method is to avoid primer altogether though. Try to get your finish work done to a level where you can prime with gelcoat/pva alone then do your final surface with the gel/duratec blend.
08 OPA High Points Champion
glassdave is offline
Old 01-31-2018 | 08:46 AM
Thanks for thé advice, the boat is already on gelcoat. I made some repaired and i want to recovered all with new gelcoat. I already use duratec and it work very well
