T&D Machine Shaft Rockers for: 2 Engines, Came off Big Chief Heads >
Old 01-31-2018 | 07:41 PM
GNJ's Avatar
GNJ
Default T&D Machine Shaft Rockers for: 2 Engines, Came off Big Chief Heads
T&D Machine Products Competition Shaft Rockers, 1.70 Ratio with less than 2 hrs run time. 2 sets with hardware - Perfect condition.
$1500.00 each set, shipping included. 813-391-1014 Gary
T&D Competition Rocker Arms are the product of years of testing and refinement. Produced with computer aided design, then CNC manufactured to ensure precision in every application. Extensive laboratory and on track testing have proved T&D rockers are the best. Large diameter, deep case hardened 8620 steel shafts, along with 2024 aluminum bodies have proved these rockers to be the lightest, most efficient, and most durable rocker arms available. All T&D Machine Products available, including all options and rocker ratios.
• Extensive Laboratory & On-Track Testing
• CNC Manufactured
• Pressurized Oiling Standard
• Stronger 8620 Steel Shafts
• Higher Quality 2024 Aluminum Bodies
• World Class 7/16" Diameter Adjusters
• Fully Rebuildable
• Easy Installation & Maintenance
Attached Thumbnails T&D Machine Shaft Rockers for: 2 Engines, Came off Big Chief Heads-20180122_174602.jpg   T&D Machine Shaft Rockers for: 2 Engines, Came off Big Chief Heads-20180122_174637.jpg
GNJ is offline
