Merc Water Pressure
Merc is 50 psi not the 100 psi anymore that they recommended. It caused issues. Look for the post I did up here about RFI and the water pressure sensor. I think it was from the guy doing an aftermarket combo oil cooler.
Merc 40 psi sensor or an aftermarket 40 psi caused issues - Just had that discussion in Person last week.
I just switched over to imcos and was concerned about this because of what I Hurd. But some friends told me I would be ok. I was running the dull water pickup lowers befor. What speeds where you running that was giving you the problems? We talking 55 to 80 or over 80. Thanks
I swapped sportmaster for imco lowers on a 39 o/l. Pressure went from just touching 30 to wrapping the gauge back around to 0. Got it down to 38 for the key west run. This was a 525 boat. The 41 with 700's had a cooling issue and merc service manual said min 30psi @ wot
