oil cooler size 1000 hp +
What are you guys running for oil cooler sizes for 1000-1200 hp? Right now my engines are running twin 13 plate coolers, and no oil thermostat. I feel that twin 13 plate coolers is too much, especially without an oil thermostat. What I plan to do is add, Harden oil thermostat/filter heads and run just one 13 plate cooler, and then run a 9 plate for the transmission. I run in Lake Michigan so the water is never over 78 degrees.
I think single 13 plate will be fine for the running you'll be doing. I would imagine Teague set those up for long hard distant runs or racing. I had all new 13's and 9's including covers and gaskets for my old builds that I regret selling. Makes such a clean simple set up. I think icdedppl ran 9's if recall for eng/trans and was fine.
I ordered senders and dash warning lights for oil temps and low fuel pressure senders also. Going to mount flush mount dash lights above each gauge.
I agree. I've ran them on all of my other engines. I'm really shocked Eickert didn't rig these with them, especially with twin 13 plate coolers. I'm currently tearing down the engines to be refreshed, and it's really obvious the oil was not getting up to temp.
maybe look at Dan Olsen oil coolers but they are not plate coolers. Not 100 percent sold on the plate coolers as I have seen many get plugged up easier than the round coolers. But we had many years of very low water conditions inwhich made matters alot worse.
How is it obvious the oil isn't getting hot enough? Seeing milky residue on teardown? When my boat was at your power level the pair of stock plate coolers was adequate if that helps any.
Straight bottoms and flat decks
I'll post some pictures of the internals the next time I'm up where I have the engines stored. When I pulled the intakes off last week. Some of the lifter tie-bars had light surface rust on them. I'm certainly no expert in this arena, but I would think if the oil was too cool it could cause this or if the block was too cold. I know I tried running a set of engines once without thermostats, and within one hour I had milky oil under the valve covers. Oil on the dipstick looked fine. I put the thermostats back in, and problem solved. As far as the actual oil in the engines, it looks fine.
I boat in relatively clean to extremely clean water. I'm going to give the plates a chance and see how they work.
