Anyone work on Ford Diesel Trucks
2010 Ford 350 / 6.4 Diesel crew cab 4 x 4. Need a better option and fix for the dumb azz set up --- the cooling hose with plastic adaptions Ford did for connections to the water circ pump. That thing leaks like a shower freaking anti freeze all over place. Prob need a lift to put the truck in the air to help with access. This truck has only 55 K miles on it.
Hey BUP, when my 6.4 hose started leaking i loosened the reservoir cap to prevent pressure in system from pushing coolant out until i got around to replacing it.After replacing hose ( $150.00 for hose ) i ran it for a month pressurized with no leaks then i loosened the cap again to prevent pressure in system and something else failing and pumping coolant in motor. It has been run in the south hard three years like this and i have added about a gallon of coolant in that time. Good luck with your repairs.
what a really dumb design this is plus a hazard dumping toxic anti freeze on the ground. So for now I am parking it on dirt so hopefully no animals or kids get into it. Kind of really stuck cause I need it to move boats around also.
Just throwing this out there b/c I don't know the 6.4 cooling hose arrangements. Have you looked at aftermarket Silicone hoses? They aren't cheap but do last and some of the kits do delete some mfg'rs plastic junk fittings?
thinking about using marine corrugated cooling hose that I can bend the paths that is needed for the correct route. By far is alot more durable than than the junk crap Ford used. Surprised the EPA does not have a federal recall on all those hose adaptions. I google it and freaking many and I mean many have leak over time --- some within a year but those were covered under warranty.
EPA is worried about marine engines having cats for emission control but yet crap like this goes on with no concern.
Ken
