Thoughts on push lock fittings? >
Old 02-08-2018 | 03:41 PM
Default Thoughts on push lock fittings?
I did a search without much luck, so what’s the OSO brain trust’s opinions on push lock fittings for oil lines? Im running -12 lines for the oil cooler etc, and put a hose clamp on them just as a nervous nelly, but have read that can actually compromise the connection. I’m running 75# cold but it’s more of the heat that concerns me as having hose pop off on a wide open run would really suck. Safe to run without clamps, or keep them on there?
Baja Rooster is offline
Old 02-08-2018 | 04:39 PM
I used the push lock on my turbo car (lots-o-heat) and never had issue. Don't skimp on the hose... I ran Aeroquip stuff and the only way to get it back apart was to cut it off.
CJSYD is offline
Old 02-08-2018 | 05:23 PM
Articfriends (think I spelled that right, probably not) if I remember correctly (suffer from CRS) is not a fan of push lock. I'm OK so long as they are low pressure, wouldn't use on oil lines. I use these
AllDodge is offline
Old 02-08-2018 | 08:22 PM
Attachment 575062
Thats exactly what I should have started with but now $500 in to push locks.
Old 02-08-2018 | 08:31 PM
Tinkerer's Avatar
I used the push lock stuff on my 598 but I used crimp rings on the oil lines.
Tinkerer is offline
Old 02-08-2018 | 08:59 PM
TomFTM's Avatar
Been using aeroquip push on fittings and hose for oil lines for years , never had a problem.
TomFTM is offline
Old 02-08-2018 | 09:27 PM
Push Lock is fine , you wont have any problems with it.
dunnitagain is offline
Old 02-08-2018 | 09:31 PM
Never had a problem.
class6 is offline
Old 02-08-2018 | 09:53 PM
Awesome. I was hoping to hear some real world experience. I used the stuff from CP rather than the Summit stuff. I read about a few failures on the Yellow Bullet forums but they were talking about tranny lines which I read could be anywhere from 130 to 230 on up. That black nylon stuff does look killer though, but not this time around. I just pulled the engine and taking care of the low hanging fruit.
Old 02-08-2018 | 09:56 PM
Once that stuff is on there it actually tightens on the fitting harder if you try to pull it off. Kinda reminds me of a girlfriend.
