Bullet odds and ends >
Old 02-10-2018 | 01:12 PM
Default Bullet odds and ends
Anyone have, or know where I can get a hold of the lower section of the hatch lift arm (part that attaches to the center stringer) and the roller at the hatch end of the ram that will work on an 88 Bullet? I have the upper arm and slide bracket, just need to piece together the rest of the assembly for a rebuild project. Also looking for a battery switch access panel as well. Thread for the rebuild coming soon!
Thanks,
John
standingBuffalo is offline
Old 02-10-2018 | 03:35 PM
Subscribed. I am right down the road in Tega Cay, if anyone can confirm if a cafe racer hatch lift arm will work I may be able to help you out.
Stuckonstupid is offline
Old 02-11-2018 | 01:48 AM
Try sending a PM to carter38. He is the Bullet guru.
Here is one of many he has done Bullet build
Griff is offline
Old 02-11-2018 | 01:57 PM
Stuck, that would be way to convenient. I’m a few miles up the lake in river hills. I am pretty sure they were the same set up as the cafe’s. Can you call me when you get a chance. 704-507-9427.
Griff, Carter’s bullets are sweet. I’ll definitely reach out. His builds have been a good inspiration for my project.
Thanks to you both for the help!
Old 02-13-2018 | 12:32 PM
VP of the tickfaw200
have one. just need to put my hands on it. have the switch panel also and can get new one more then likely. we remade all the stuff.
caseyh is offline
Old 02-13-2018 | 12:33 PM
shoot me a text 225-445-2110
caseyh is offline
Old 05-11-2018 | 06:24 PM
TTT
thought I had the hatch actuator lower arm located but I was mistaken. Oh anyone has one to part with let me know. Thanks!
