32 fever exhaust >
32 fever exhaust
32 fever exhaust
Old 02-14-2018 | 05:53 PM
Default 32 fever exhaust
I have a 96 32 fever. I have a captains call exhaust on it now and would like to get rid of it. Curious if anyone on here had done it before or knows anything about switching exhausts. Thank you
ruby6.7power is offline
Old 02-14-2018 | 07:35 PM
Just replace diverters and cap or remove y pipes.
Crude Intentions is offline
Old 02-14-2018 | 07:37 PM
I removed mine, HP500EFI motors. Then did dry to tip tails, mocked them up using PVC drain pipe. When done put screws into the PVC marked them up and where I needed the water fitting. Sent the mock ups to CMI and had them make up the tails.
Wildman_grafix is offline
Old 02-14-2018 | 08:43 PM
I’m shooting for the exhaust to exit on either side of the swim platform above water level. What would I have to do to block off the existing holes for exhaust on both settings of the captains choice? Thank you
Old 02-14-2018 | 08:45 PM
I’m shooting for the exhaust to exit on either side of the swim platform above water level. Just curious on what I have to do to block off the existing exhaust holes thru the hull. I hope it’s not too much of a pain I need more noise! Motors are 502s thank you
Old 02-15-2018 | 07:14 AM
Buy headers, It will be loud
cjo632racing is offline
Old 02-15-2018 | 08:02 AM
Lol I want to but they’re expensive. I’m trying to change just the tails. But don’t really know where or how to plug the holes for the silent choice on captains call
Old 02-15-2018 | 08:57 AM
Well first thing, you can pull motors and they sell a plate to block of the thru prop "hole".
But do you mean you also want to get rid of the transom holes?
Old 02-15-2018 | 09:30 AM
I have a blown motor that’s coming out and while it’s out I want to get a new exhaust on there. Don’t they make an exhaust that exits next to the swim platform? Like on the down pillars? Or do i use the transom holes I have now?
Old 02-15-2018 | 11:42 AM
No not on the 32’s. So when the motors are out take the silent choice off, put the blocking plates on and then make or buy tails.
It it would be a big PITA to go out the sides but if you do then Glass the transom holes up at that time.
