Question on shallow water operation?
I do apologize beforehand if this topic has been already addressed. I have a 28 foot deep v speed boat and for some reason as much as I try to navigate shallow waters or sand bars I always end up sucking up dirt and sand and each trip is costing me to have my mechanic come out to my house and fix my boat after each run. I live in Florida and this mainly happens when I’m out in the ocean and tend to visit and sand bars, or shallow water areas. Mind you I had a depth finder and I’m extrely careful. Or should I just plain stay out of shallow waters in general? Lol
It has a bravo x outdrive and onboard motor. Any suggestions? Heck I was even wondering if there is a portable trolling motor to use in those occasions or circumstances? Any and all help and advice would be appreciated. Thank you in advance, GABE
Interested in this topic as well. I have had a similar issue since I upgraded to an IMCO lower, particularly with sucking up sand at a sand bar. I try not to start the boat until I am back in deep water, but can only push it out so far and sometimes it is unavoidable.
Would a sea strainer help with sand as well?
I get this a lot down here as well, the strainers help a little just because it gives it a dump spot but I now have a dual water pickup on one drive. Lots of shallow places here, even getting into some fuel docks I will trim up and still kick a ton of stuff up.
The difference in what I suck up between it and the low water is crazy, I want another one. Also no water pressure issues with the dual.
Sand/Sea strainers from Hardin:
Hardin Marine - Sand Strainer Kits
Depending on the application, you may be able to have your water pickup(s) modified.
Which option does your Bravo X outdrive have now?
-Dual Water Pickups
-Low Water Pickup
-High Water Pickup
You can't normally pilot your boat through sand, but occasionally it happens. You also can't trim it to the moon in efforts to idle though, as that will destroy your U-joints and other parts. If you boat to regular locations, spend time dialing in your GPS with water depths as well as 'breadcrumbs' for paths you have taken in the past with no issues.
Due to the shallow waters of the West Coast of Florida, there are quite a few folks that have made the switch to outboard powered boats that can be trimmed up high for idling through shallow water.
-Dual Water Pickups
-Low Water Pickup
-High Water Pickup
Outboards with hydraulic jack plates. How many remember the Mercury scissor jack. These are good for low water conditions.
for inboards and I/O's ---- Look at Hardin duel screen sea strainers. It would prob be best to call them next week. Alot of their employees are at the Miami boat show.
Low water levels for us is very common as well.
With crap sucked up from low water conditions especially in non closed cooled engine apps - the t stat and its housing especially if has the check balls in the housing is also another problem area that gets jammed up. Also the exhaust manifolds / risers.
And really needs to be checked for Volvo Penta apps as well.
