Best book for Mercruiser 525SC rebuild >
Old 02-15-2018 | 10:52 PM
Default Best book for Mercruiser 525SC rebuild
Doing a rebuild of a mark IV 525SC and need a good book/ info to guide me through it, any recommendations?
Mohavvalley is offline
Old 02-16-2018 | 02:14 AM
Get the Mercruiser Service manual. I think it is the HP3 manual. It will have all the specs.and instructions.
Griff is offline
Old 02-16-2018 | 06:47 AM
Your Checkbook...lol..
Chris
Blueabyss is offline
Old 02-16-2018 | 09:17 AM
I thought this has incorrect information in it?
What about the seloc manual?
Old 02-16-2018 | 09:35 AM
BUP
Seloc is an entry level manual.
I have all the OEM service manuals for Mercruiser including the 525 SC. also if needed I can provide all the OEM Service Bulletins per that engine application via engine serial number is needed. also if one knows the year model of the engine helps as well.
BUP is offline
Old 02-16-2018 | 11:49 AM
Thanks BUP,
It's Built in 1994, have not confirmed if it's a Gen 4 or 5 yet I need to check stamping.
Tried PM'ing you but your box is full, let me know when you've cleared some space and I'll send you the serial number for service bulletins.
Mercruiser says it takes Manual Number 848294-1
Old 02-16-2018 | 02:11 PM
BUP
some room currently for a PM. Can not say for how long thou.
BUP is offline
Old 02-16-2018 | 03:01 PM
If it's a '93 it's definitely a Gen IV. Fuel pump is mounted on the block. It's basically a GM L88. 9 to 1 comp, 4 bolt main, steel crank, 7/16 rods (dimple) and rect. heads. rebuild is pretty straight forward. Nothing trick to it. There's plenty more you could do in a rebuild for gobs of hp. It's all about the $$$$$. Any good automotive machine shop could do it. Any marine rebuilder will charge you double for the same work.
gofastboater is offline
Old 02-16-2018 | 07:45 PM
You wern't joking, it's full again, guess your popular
PM me a good email and I can send it to you there OR let me know when you've cleared some more room.
Old 02-16-2018 | 09:37 PM
BUP
^^^^ I know its common. If this was a board full of women I would take that as a huge positive. haha
Actually I do not mind, most of the PM's are about Fuel injector questions since I provide fuel injector flow testing and cleaning services.
BUP is offline
