Crane 731 vs 791 >
Crane 731 vs 791
Crane 731 vs 791
Old 02-16-2018 | 11:53 PM
Default Crane 731 vs 791
Trying to see why the 731 grind is the overwhelming preferred choice when the 791 is the same specs but with 114 loa compared to the 731's 112 loa.
I will be running my exhaust out the prop so I'm thinking the 791 is the wiser option.
Am I wrong in thinking this?
pjv911 is offline
Old 02-17-2018 | 01:41 AM
Never even heard of the 168791 until now. It must be a newer grind. I doubt you'll see any difference from the 731 in power or reversion aspects.
IMO, its a waste of time to try and bump the hp with thru prop exhaust. It will choke off any gains in power.
Griff is offline
Old 02-17-2018 | 08:07 AM
the boat will likely be slower
adk61 is offline
Old 02-17-2018 | 12:38 PM
Not trying to bump power. Its the overlap that is better for reversion.
In any event torque will still be better in the cruise rpm range. As compared to the stock cam I mean.
Its not a new grind. The Crane techline guy said its been around for over a decade and has also been the choice when dealing with the more respected marine engine builders.
I will most likely install a silent choice in the future so I will benefit further in the future.
pjv911 is offline
Old 02-17-2018 | 12:45 PM
http://www.cranecams.com/140-143.pdf
pjv911 is offline
Old 02-17-2018 | 12:51 PM
It will still most likely revert water with stock manifolds and the short stock risers.
I'm sure the Crane techline guy didn't give you any names of those builders.
No respected marine engine builder is going to upgrade to that cam and run stock cast exhaust. through the prop.
Griff is offline
Old 02-17-2018 | 05:41 PM
Im just going to put this in nice easy to understand verbiage....
Trying to run a perfomance motor with thru prop exhaust is like trying to drink beer and piss thru a coffee filter and wondering why you get wet.......
phragle is offline
Old 02-18-2018 | 01:14 PM
I picked up 731 Crane can with dyno time only and might sell it. I picked it up because it may have worked well enough with my stock valve train but since I’m looking at an extensive refresh I may go all the way to the 525EFI unit. It’ll be a couple weeks before I’m sure though.
Baja Rooster is offline
