Trim Tab wiring Diagram on a 2007 Baja Outlaw 26 >
Old 02-21-2018 | 11:44 AM
Default Trim Tab wiring Diagram on a 2007 Baja Outlaw 26
Hello everyone, I am New to this forum. I recently purchased a used 2007 Baja Outlaw 26 with 496HO and everything is working BUT the trim tabs and trim on toggle switches. I opened up the 4 toggle panel and saw many wires pulled off the back of terminals. Ex: there was a red, green, and blue striped wire hanging loose. The reason: some idiot who installed the hydraulic hoses for the Mayfair steering system ran them on top of the wires going to the back of steering wheel at side of helm. These toggles have 8 male connectors each and there are 4 toggles. I can take a picture of this helps. I called Iconic Marine Group (owners of Baja since 2010 I believe) and they had no records of wiring diagram for the trim tabs and trim. If anyone owns this model, I sure would be happy to pay someone to unscrew the back panel and take a few pics. Or if anyone has knowledge, I sure would appreciate some input. Thank you all!
AaronTN is offline
Old 02-21-2018 | 12:19 PM
"Ex: there was a red, green, and blue striped wire hanging loose."
Typically:
RED= +12v hot to switches
BLUE= Switch +12v out to UP
GREEN= Switch +12v out to DOWN
Hope this helps and welcome to forum.
GLENAMY 242SS is offline
Old 02-21-2018 | 12:47 PM
Default Glenamy
Thank you for the response and consideration for help. I am going to post some pics tonight of these terminals (front and back) for better understanding. You are correct on the color reference but I have not a clue which prong they go on the backside of Toggles. The green wire is doubled and one connection is loose. Appreciate all the help I can get with this. I have been pulling hair for days.
AaronTN is offline
Old 02-21-2018 | 01:08 PM
The green wire would connect to the bottom/down side of whichever switch does not have a green going to it.
The red will connect one of the center poles on one of the switches. Since nothing works, that will probably be the main power to all of the switches.
Griff is offline
Old 02-21-2018 | 01:18 PM
What tabs do you have, Bennett or K-Planes. or?
Old 02-21-2018 | 01:49 PM
They are Lenco Tabs... I am trying figure out how to post pics on this thread.
AaronTN is offline
Old 02-21-2018 | 02:00 PM
You cannot post pics unless your a paying member or you use a third party site and link it here
AllDodge is offline
Old 02-21-2018 | 03:36 PM
Thank you. Again, I am new to this forum and learning. I will give a better description of the diagram tonight. I will see what it cost to be a member. I have got some of the best advice so far. Kind regards
AaronTN is offline
Old 02-21-2018 | 03:41 PM
What, if any, wires are still connected and what is their positions?
Old 02-21-2018 | 03:43 PM
I just looked into the membership, etc. It states I will be able to PM more individually, view more uncensored post, but does not state I can attach pictures. Are you sure before I spend $44.95 for a year?
AaronTN is offline
