Bravo XR Rebuild
Just recently bought a 2008 Advantage X-Flight 29 with the 525 EFI and Bravo XR drive. First time out the drive, while under way, had a very loud whining sound that could be heard over the open exhaust sound and spraying drive oil all over my engine bay even with a drive shower. I only noticed this when I got home and opened the engine bay. Another issue was the fact that the drive alarm did not go off once the drive oil level fell below the add drive oil marker on the remote drive reservoir. Was told by the previous owner the whine was normal for that drive and once or twice a season he had to top off the drive reservoir. My last two boats had Bravo one drives so I believed what he had told me. Decided to take it in for servicing on Monday to play it safe and now find out the drive was about to fail. Looks like both the upper and lower gear sets will need to be replaced alone with some bearings. Lesson learned, as they say, buyer beware.
I too just took apart my XR and found the upper and lower gear sets were pitting. There was no whining with mine. I did break my other side last year so i was looking in to this one this year to prevent another break. I think my issues was from poor oil and maintenance from the previous owner. Last summer was my first with the boat and it only has 260 hours on 525's in a 35 fountain. I am just starting to look into other options
The spraying drive oil is most likely coming from the reservoir, it would be very tough for drive oil to get thru the transom assembly. There is an o ring in the cap of the reservoir, and if thats gone it will spray drive oil all over your engine and bilge area.
Well the drive was completely rebuilt. Will be picking up the boat later next week. Because it has a lower water intake what is the best way to flush. I have just been placing the muffs over the vertical water intakes but doing so just causes a lot of water to be dispersed through the low water intake causing less water to get up into the motor for flushing. Should I order the OEM Mercury low water intake flusher and if so who would have the best pricing?
Well the drive was completely rebuilt. Will be picking up the boat later next week. Because it hasw a lower water intake what is the best way to flush. I have just been placing the muffs over the vertical water intakes but doing so just causes a lot of water to be dispersed through the low water intake causing less water to get up into the motor for flushing. Should I order the OEM Mercury low water intake flusher and if so who would have the best pricing?
If you have DWP on your lower and a someone to help you. While drive is dry place tape on lower water pick up and muffs on side pick ups. As you start motor have other person turn water on. This will work fine. The trick is the person turning water on isn’t to quick and blow tape off
