Livorsi GPS Speedo Not Working
Check the Antenna first.
Mine is an '06-'07 vintage, has the little rectangular antenna in the locker behind the dash. It was stuck on with double sided tape and had come loose. Hanging by its wire in the bottom of the locker. Stuck it back on in an upright position, all good.
I think there are different fault codes identified by what the gauge shows. Mine would automatically jump to the 9 o'clock position and not move which means antenna issue.
Use Google, there's many threads on here and other forums. Good luck!
RR
RR
If you go the Livorsi's web site under Tech tools and then, GPS Speedo, they will walk you through it. I believe they show 2 speedo's of different years used.
Tech Tools - Product manuals and installation guides - Livorsi Marine, Inc.
