LSx engine parts, 243 heads, 5.3 block, 6.0 Intake, Harness and ECM >
Old 03-05-2018 | 10:48 AM
Default LSx engine parts, 243 heads, 5.3 block, 6.0 Intake, Harness and ECM
I Have a set of stock heads from an 02 ZO6, these are the 243 heads with the lightweight valves. Stock yellow springs. Fully assembled and removed at 50K miles to install a set of ported heads. 210cc intake ports 64cc chambers and these will rev to 7K without valve float! Asking 650
I also have a set of Patriot Gold Dual Spring Kit with titanium retainers, kit is complete brand new. Asking 350 for the spring kit.
I have a 99-04 5.3 shortblock, complete and assembled minus the oil pan. Has a busted ring land on #1 piston. I have a set of slightly used Mahle Forged 3.905 5.7 pistons and rings. Block can be bored to fit these pistons and have a low buck 5.7. With the 243 heads and a 220/220 .550/.550 lift cam on a 112LSA this would be a ~375-400HP engine. Great low buck upgrade for that old tired 260HP SBC. Asking 500 for block and pistons.
I also have a 03-06 6.0 truck intake with a DBW throttle body and stock 28lb injectors. Asking 125 for complete intake
i also have an 07-08 5.3 truck E38 ECM engine wiring harness. This is perfect for a boat as it’s just the engine harness only no transmission controls. I don’t have the ECM but will get one and include it in my asking price. It will have to be programmed for your engine build. Asking 250 for harness and ecm.
HotRodV6 is offline
