Mark IV 502 Oil Cooling Questions to 540 >
Old 03-06-2018 | 07:51 AM
Default Mark IV 502 Oil Cooling Questions to 540
Last year I took everyones advice and built a nice 540 for my Powerquest. The only thing I didn't address was the oil cooling system at all, other then a Melling 10778 oil pump and a 10qt pan. After reading thru numerous post and articfriends oil pressure hardware thread I dug into the system from the factory 502. What I discovered is my oil cooler is 3x20 and my lines after removing them all have a 1/2 ID. So now im a little confused, alot of people post about upgrading there Gen V and VI stuff from 2x18 to 3x18 and from 3/8 lines to 1/2 or 5/8. So with my cooler and lines being decent size am I able to keep the the cooler and lines I have, or should I replace my line with -12AN which should be 5/8 ID. Just seeing what people think, or others have done. Thanks
rjewell1988 is offline
Old 03-06-2018 | 08:02 AM
Wobble's Avatar
SORE MEMBER
the gen 4 seems to run hotter oil temps, I ended up with Teague's offshore oil cooler. I still see higher temps than I would like on extended WOT runs. #12 lines swept elbows, remote filter drilled out internally, plugged bypass in remote adapter. The motor is still running well after 10 years.
Wobble is offline
Old 03-06-2018 | 08:18 AM
F-2 Speedy's Avatar
What HP is the 540 making ? I don't really see an issue with the lines and cooler you have if there is no 3/8 ID bend's in any of the fittings.
F-2 Speedy is offline
Old 03-06-2018 | 08:20 AM
OK, do you know what size your stock cooler was and then the size you upgraded to by chance?? And I definitely like the idea of larger lines so far and try to eliminate and 90 degree elbows. Unfortunately last year I ran stock gauges and never had an oil temp sensor, new gauges is on the list. I figure while the motor is out of the boat this winter I want to address any issues while its tore down.
Old 03-06-2018 | 08:24 AM
It should be in the 650 range I would imagine. I never had it on a dyno'd but im running 9.1:1 compression. Canfield 119cc heads, currently be lightly worked over by Jim V. Crane 741 cam with a Merlin intake and Quick Fuel 1050 with lightning headers. I was hoping I could atleast reuse the cooler being that it is 3" already. Its just hard to find Mark IV info. Everything ive read says to switch to a 3" I just have no idea how good the stock 3x20 is and if it was normal to be put on the 502's as well.
Old 03-06-2018 | 08:45 AM
Wobble's Avatar
SORE MEMBER
went from 2x12 to the offshore cooler, water temps get very warm down here, did not want to take chance, 600hp N/A dyno verified
Wobble is offline
Old 03-06-2018 | 08:50 AM
F-2 Speedy's Avatar
A Whippled Merc 525 runs on a stock cooler and lines and makes in the 800hp range........
Old 03-06-2018 | 08:58 AM
OK awesome. What size cooler comes an a 525 I hear alot of guys upgrading to the 500 or 525 cooling systems for a budget way to go.
Old 03-06-2018 | 09:02 AM
Are you sure its getting to hot, have a gauge on it?
AllDodge is offline
Old 03-06-2018 | 09:04 AM
F-2 Speedy's Avatar
I think its a 3x18 or 20...here's one
