Why don't you see more bigger CI Na combos >
Old 03-06-2018 | 06:09 PM
Default Why don't you see more bigger CI Na combos
Why don't more people build big cubic inch NA combos vs roots or centrifugal supercharger. With the cylinder head technology and intake manifolds and things of that nature nowadays you can make big Power naturally aspirated on pump gas also.
Single cat is offline
Old 03-06-2018 | 06:23 PM
GPM
Depends on what you call big power, you're not going to see 1400hp unless you go 860 cubic inch.
GPM is online now
Old 03-06-2018 | 06:46 PM
Default Engine
, I was referring more to that 900 horsepower 1000 horsepower range.
Old 03-06-2018 | 06:57 PM
F-2 Speedy's Avatar
I think you continue to compare drag race engine to marine, my buddies Top Sportman 632 made 1320hp with no juice and will push his door slammer to 203 mph on 3 stages.....put it in a boat and its a turd..........3200 lbs vs 10K,constant load
F-2 Speedy is offline
Old 03-06-2018 | 06:59 PM
GPM
Then I'm guessing, lower RPM, milder cam, possibly more torque using a supercharger, more user friendly in a boat.
GPM is online now
Old 03-06-2018 | 07:02 PM
I have yet to see a 900hp or 1000hp N/A marine engine, go 250-300+ hours without pulling a valve cover. Plenty of forced induction builds that have done that, for many years. Also, that idle at 700rpm in gear all day.
MILD THUNDER is offline
Old 03-06-2018 | 07:03 PM
1000hp NA is a screamer and hard to get to those high power rpms. Roots blowers are more torque down low to get these big pigs moving. Now you can put a 1000hp screamer into a 2000lb V-Drive hull and it’ll move along just fine and many people do.
Baja Rooster is offline
Old 03-06-2018 | 07:13 PM
jeff32's Avatar
so would you guys say in real world, a NA engine would be maxed out around 650 -700 HP to be dock friendly and reliable for a couple hundred hours, above that, need a blower to keep them dock friendly and reliable?
that would be my guess, right?
jeff32 is offline
Old 03-06-2018 | 07:19 PM
Tinkerer's Avatar
I am at 800+ HP with 598 CI and it idles at 750 RPM in gear and turns 6400 RPM at top speed. I did build it with the intentions of installing a supercharger eventually.
Tinkerer is offline
Old 03-06-2018 | 07:23 PM
Sonnys makes a bunch rated for marine but ive never seen one in a boat.
https://www.sonnysracingengines.com/...s/boat-engines
Keith Atlanta is offline
