Arneson Parts
Old 03-14-2018 | 08:33 AM
Default Arneson Parts
I'm looking for a chain for an ASD 7. If you have one but don't want to part with it I'd pay to rent it so I can get one made. 901-491-4500
payuppsucker is offline
Old 03-15-2018 | 03:32 AM
Just call Rik. He has these in stock and if its the older ASD6 you can upgrade to the beefier gears and chain but you did say ASD7. Pricing from Rik on these isnt bad at all
kaje is offline
Old 03-15-2018 | 07:59 AM
I've been trying to get parts from Rik since October. He has nothing in stock.
Old 03-15-2018 | 08:26 AM
Can you use your old chain and have a copy made from that one?
green lightning is offline
Old 03-15-2018 | 08:28 AM
Possibly, if I knew the correct length. Unfortunately mine is in pieces so I'm unable to determine the length.
Old 03-15-2018 | 09:56 AM
Sorry to hear about your chain issue , but I only have one and it's in the boat and kind of a pain to take the chain box apart , I do have some studs and seals
Old 03-15-2018 | 10:02 AM
Yea, I wouldn't want you to do that. Hopefully I have one located, waiting on the guy to get back from Costa Rica. Thanks.
Old 03-16-2018 | 03:58 PM
bor's Avatar
bor
Default Asd 7 chain
i have a pair asd 7 m drives and have one apart but what ratio do You have as i think they could be different in length .
as im located in europe i could measure it for You
bor is offline
Old 03-16-2018 | 05:29 PM
I have 1.3:1 ratio, large sprocket has 34 teeth and the small sprocket has 24. My sprockets are 1.625 inches in width. Thanks for any help you can provide.
Old 03-17-2018 | 04:40 AM
bor's Avatar
bor
I have 26 teeth small and 34 teeth big Sprocket there 1 7/8 “ inch wide
the chain has 27 links when stretch out its 12 .5 “ long outside to outside and 11.5 “ inside to inside
the outher diameter is 28 1/8 “
hope this helps
bor
bor is offline
