Livorsi - Upgrading Your Dash Is Easier Than You Think
Administrators
Summer will be here before you know it, so now is the time to give your dash a face lift. Upgrading your dash is easier than you think with the Livorsi standard size or monster series Mega and Race Gauges. Each gauge uses a Deutsch connector to make the connection waterproof and a simple plug in application.
Our line of powder coated Billet Accessories allows endless color accents that are incredibly simple and can be installed with minimal rigging experience. Simple upgrades include adding optional bezels to your gauges.These are powder coated rings that sit between your gauge and your dash. Bezels are available in 12 colors or in stainless steel with a polished finish.
Dash Designer
You spend 90 % of your time in front the dash so why not give it that boat show look while adding value to your boat.
Our Livorsi DashDesigner is a virtual dash to help you mix and match colors so you can dial in on the right look.
View our color guide
View our custom gauge gallery
Platinum Series Controls
Don't forget your throttle controls. With the new Platinum Series you have your choice between three styles: Standard, Arched and Billet. Controls are available in an array of colors and configurations including fully mechanical, fully electric or hybrid.
Learn more hereNEW! Livorsi Wheels
· 13 1/2" diameter
· Brushed anodized aluminum
· Meets ABYC P22 standard
· Standard 6 bolt pattern (same as Momo/Isotta wheels)
· Corrosion resistant
· Brilliant colors that won't fadeClick here to view our catalog
Links
· LED Underwater Lights
· Trim Tabs available in color
· Hydraulic Pumps
· LED Position Indicators
· LED Position Indicator Calibration Video
· Livorsi Electronic Throttle-Mechanical Shift
· New Options for Vantage View® CAN Bus Gauges
· Livorsi Marine DashDesigner
