Stelling Box Bearing Carrier
here is the parts breakdown, it says 5.0 alpha but the part #'s are the same as the driveline
i have that came off a big block, same stuff.
Hardin Marine - Jackshaft Main Kit
I think I may have what you are looking for. It appears to be the same as the Merc part # 817416A4, the only number on the carrier is 55434C. This is for an SSM set up, again, not sure if it would work for your application. If you want it let me know. I have 2 of them, and will sell them for less than half what Hardin wants. It will be only the carrier. Everything else is going in to a different style carrier for my Merc boxes.
Does not look like the ones on my Stelling boxes. Call Randy at Sanger ski boats. He worked for Jack the owner of Stellings forever. I am not sure if he is still there. It is so sad his daughter just closed Stelling to concentrate on Sanger. She should have sold it.
If you know someone that has a Bravo stagger you can measure the bolt spread and height. If you do not know of one next time I am at the Donzi I will measure.
