Dead battery
Old 03-31-2018 | 09:13 AM
Default Dead battery
How can I open the engine hatch on a 1993 top gun if my battery is dead . I know there is a way but I can't find the post
riski bidness is offline
Old 03-31-2018 | 09:37 AM
Wobble's Avatar
SORE MEMBER
if there is no mechanical bypass, you could open dash and hook up a 4 or 10 amp charger (no more than that) to battery positive red and ground block, might take a while, if you have an amp then that should have some good sized cables where you can charge faster
Wobble is offline
Old 03-31-2018 | 10:48 AM
Posts should be under back seat
NitroSun is offline
Old 04-01-2018 | 02:20 AM
Isn't you battery switch under the back seat???
Griff is online now
Old 04-02-2018 | 02:17 PM
Wobble's Avatar
SORE MEMBER
thought about that, but usually, no ground available there.
Wobble is offline
Old 04-02-2018 | 03:09 PM
I've had this happen, the pump is under the rear bench. Jump it with jumper cables to a car battery or spare, etc. Green and blue wires I think go up/down.
frickstyle is offline
Old 04-02-2018 | 03:21 PM
green goes down, blue goes up. Negative lead to black
Unlimited jd is offline
