Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Removing Saltwater Rust from Cast Iron to Epoxy Prime? >
Old 04-15-2018 | 09:53 AM
Question Removing Saltwater Rust from Cast Iron to Epoxy Prime?
I have 2 Velvet drives that were Saltwater used ,I had them sandblasted . The rust came back with in a day! I want to Epoxy Prime and Paint , but
dont want the primer lifting in a years time , I would use a self etch or rust converter , but the primer ( Southern Poly ) says not too use over either. .
Directions say that it will handle some flash rust , but this is some agressive rust . I think the tranys were submergered. Any suggestions?
dunnitagain is offline
Old 04-15-2018 | 10:57 AM
jeff32's Avatar
curious to read the answer! I'm surprised to read rust comes back within a day after sandblast! Geeez I never thought salt was that much aggressive and corrosive!
jeff32 is offline
Old 04-15-2018 | 11:54 AM
cast iron is often porus, and sand blasting does not remove the contaminates except on the surface. Washing the housings (soak if you can) with soap/water or Beter yet acetone/alcohol and baking in a oven to evaporate whatever is in the iron will help a bunch. Sometimes it takes several rounds of cleaning, and other times it never really cleans up if it it's really bad.
sailtexas186548 is offline
Old 04-15-2018 | 01:20 PM
I was shocked as hell when the rust came back !
Im going to try Evapo Rust , Ive used it before but not on cast and not under paint ,
Old 04-15-2018 | 05:40 PM
I've always used a rust remover with phosphoric acid (Evaporust maybe a brand name product with phosphoric acid). It's a great rust remover before paint application, the rust removal process results in the formation of iron phosphate which is more stable than iron oxide (rust).
modvp is offline
Old 04-15-2018 | 05:49 PM
after removing rust dry it and coat it with diamond clear by KBS . about ready to use some evaporust to clean out the water passages in a couple set of heads. dont think it works well on aluminum it can be brush, rollered, sprayed. it can be used as a sealer under coat and a very glossy over coat. have used it for both sticks better than glue handles tems in the 450 range.
KBS : STOP RUST : PREVENT RUST : RUSTY METAL PAINT :: PAINT RUST
turbo2256b is offline
Old 05-21-2018 | 07:29 AM
Did this work for you? Looking for same kind of solution.
MartijnAir is offline
Old 05-28-2018 | 04:57 PM
The evaporust works very good , it has been unpainted since I started this thread and it still has not returned.
