Headers using closed loop to cool >
Old 04-19-2018 | 04:19 PM
Default Headers using closed loop to cool
Ok this may seem a little odd and would need to modify the headers, I see a lot of aftermarket closed loop cooling systems fitted to marine engines. Some are just engine cooling and some are engine and manifolds cooling with the riser raw water cooled. I've been looking at upgrade manifolds and headers of late and just thought why could you not cool the headers with the closed loop cooling.
I do realize that some modifications would be needed to the headers to stop coolant from exiting the rear but can anyone see a real reason why this would not work as long as the heat exchanger is large enough.
Camalot is offline
Old 04-19-2018 | 04:44 PM
It has been done.
snapmorgan is offline
Old 04-19-2018 | 04:58 PM
Ayuh,..... Is yer motor currently a closed coolin' system,..??
If so, are the manifolds included in the system,..??
If Not,.... Addin' it to a used motor, usually ends in disaster, with a clogged unrepairable exchanger,....
Bondo is offline
Old 04-19-2018 | 05:30 PM
Yeah it's a new engine going in so no problem there thanks.
Camalot is offline
Old 04-19-2018 | 05:32 PM
Originally Posted by snapmorgan
It has been done.
I thought it lwould have been do thanks
Camalot is offline
Old 04-19-2018 | 06:36 PM
you need a much larger cooler than stock.what exhaust manifolds do you have,,cast iron or aluminum?
sutphen 30 is offline
Old 04-19-2018 | 07:15 PM
As it's a new engine going in I won't be using the old stock manifolds, I guess I'm lucky being a Volvo Penta technician and rebuilding a lot of our Canadian government water crafts I have a load of 41 series heat exchanger To Hand which are more than big enough for the job.
I was hoping to hear from someone that has done it.
Camalot is offline
Old 04-20-2018 | 01:40 AM
I guess my question would be why do it??
I only see an advantage if it used primarily in salt water.
Griff is offline
Old 04-20-2018 | 04:40 AM
Only real reason is I have a chance to get a set of new fresh water Lighting headers as a trade for some work to a boat. I use the docks at work which is salt water also lake usage which is a little brackish. Thanks for the replies
Camalot is offline
Old 04-21-2018 | 08:40 AM
I have done it,,thats why I said you'll need a bigger than normal exchanger and even then you'll need the water flow to keep it from boiling over under a heavy load.good luck,watch your gauges.
