Mystery hose in transom assy??? >
Old 04-28-2018 | 12:15 PM
Default Mystery hose in transom assy???
On a Bravo one drive there is a small black hose about the same size as the speedometer hose right close to the hose that supplies cooling. Its attached to the bell housing close to cooling hose and I assume it goes somewhere into the gimbal housing but cant seem to find where. I saw it there not connected to anything and want to put it wherever it belongs. So does anyone know what this is and where it goes??
iroc fan is offline
Old 04-29-2018 | 06:17 AM
Ayuh,..... Are you sayin' it's Not the speedo hose,..??
The oil hose is slightly bigger,.....
Bondo is offline
Old 04-29-2018 | 08:00 AM
Trim sender wires are in that vacinity
JaayTeee is offline
Old 04-29-2018 | 07:19 PM
convincor's Avatar
Like this?
convincor is offline
Old 04-30-2018 | 07:28 AM
Yes I do now believe its the speedo hose.. Where do I plug this in? Guess I didn't notice the speedo not working since I only use the speed on the GPS.
iroc fan is offline
Old 04-30-2018 | 07:32 AM
convincor's Avatar
Your probably missing the pick up. ∆
Old 04-30-2018 | 10:43 AM
BUP
lets ask first and foremost ----- do you a GPS speedo cause if you do the OEM speedo line gets disconnected ?
BUP is offline
Old 04-30-2018 | 10:58 AM
convincor's Avatar
"Guess I didn't notice the speedo not working since I only use the speed on the GPS"
