Camshafts explained? >
Old 10-22-2002 | 06:47 PM
Default Camshafts explained?
I am having a hard time finding the right cam for my engine.
I understand what duration and lift are but how does this relate to the spec numbers Say for example...a cam with an advanced duration of 234,246 @50, and a gross lift of 497,504 w/a 112 loeb center. what exactly do all of these numbers mean, could someone please explain this?
Also I have been told to use a cam close to what I already have so I dont have to buy different rods. Would a cam w/ 242,250 duration and 507,532 lift be considered close to the above specs
THRILLSEEKER is offline
Old 10-22-2002 | 08:00 PM
formula31's Avatar
I have a couple good books on high perf chevy engines small block and big block that explains a lot. Your welcome to borrow them. And Dennis Moores marine version is liked by many but I dont have that one. Email or PM me your address and Ill send it off. Pulled mine out today, done for the year.
formula31 is offline
Old 10-22-2002 | 08:39 PM
KAAMA's Avatar
Thrillseeker,
Cam specs depend on what cubic inches your engine is, what application you're using it for (I'm sure you are refering to a marine application)---this will relate to what RPM range you will be running it in. For a hi-perf pleasure boat I would say the highest RPM you'll be running is about 5500rpm for a V-8.
So how many cubic inches is your engine?
Is it a stock MerCruiser engine---what model?
Are you running a better than stock exhaust system?
Unless I am missing something, I think you were told to stay with a cam close to the stock specs because you can still use the same valve springs. You might be better off going with new valve springs to match the cam. If you are going to spend the money on a new cam you might as well get one that's going to give you a decent power increase---otherwise you might just be wasting your money.
What kind of cam were you considering? A flat tappet hydraulic, Or a hydraulic roller cam?
KAAMA is offline
Old 10-22-2002 | 11:41 PM
Thrill, have you looked at Summit's cams. They have a lot for small blocks. They have one that is pretty close to what you have. Its a 234/244 with .488/.510 lift on a 114 lobe sep(part #sum-k1107) I actually had that same cam in blown 350 in prostreet car and never had any problems. Made good power thru 6000rpms. they also have a 244/254 with .510/.533. You'd probably need new springs that one.
Griff is offline
Old 10-23-2002 | 02:29 AM
FindMe
Valve Timing Tutorial
In an effort to simplify what actually happens inside an engine, COMP Cams® invites you to "take a walk" inside a typical engine, just like the one you might have in your car. We will discuss valve events, piston position, overlap and centerlines.
Although we can not explain cam design in such a small space, we might be able to clear up some of the most misunderstood terms and make clearer what actually happens as the engine goes through its four-stroke cycle. We will graphically illustrate the relationship between all parts of the engine and try to help you understand how the camshaft
affects the power of the engine. Put on your walking shoes, open your eyes and get ready for a good look inside thisengine.
We begin with the piston all the way at the top with both valves closed. Just a few degrees ago the spark plug fired and the explosion and the
expansion of the gasses is forcing the piston towards the bottom of the cylinder. This is the event that actually pushes the crankshaft around to create the power and is referred to as the "power stroke" (figure 1).Each "stroke" lasts one half crankshaft revolution or 180 crankshaft degrees. Since the camshaft turns at half of the speed of the crank, the power stroke only sees one fourth of a turn of the cam, or 90 camshaft degrees.
As we move closer to the bottom of the cylinder, a little before the piston reaches the bottom, the exhaust valve begins to open. By this time most of the charge has been burned and the cylinder pressure will begin to push this burnt mixture out
into the exhaust port. After the piston passes the true bottom or Bottom Dead Center, it begins to rise back to the top. Now we have begun the exhaust stroke, another 180° in the cycle (figure 2). This forces the remainder of the mixture out
of the chamber to make room for a fresh, clean charge of air-fuel mixture. While the piston is moving toward the top of the cylinder, the exhaust valve quickly opens, goes through maximum lift and begins to close.
Now something quite unique begins to take place. Just before the piston reaches the top, the intake valve begins to open and the exhaust valve is not yet fully closed. This doesn't sound right, does it? Let's try to figure out what is happening.
The exhaust stroke of the piston has pushed out just about all of the spent charge and as the piston approaches the top and the intake valve begins to open slowly, there begins a siphon or "scavenge" effect in the chamber. The rush of the
gases out into the exhaust port will draw in the start of the intake charge. This is how the engine flushes out all of the used charge. Even some of the new gases escape into the exhaust. Once the piston passes through Top Dead Center and starts back down, the intake charge is being pulled in quickly so the exhaust valve must close at precisely the right point after the top to keep any burnt gas from reentering. This area around Top Dead Center with both valves open is referred to as "overlap". This is one of the most critical moments in the running cycle, and all points must be positioned correctly with the Top Dead Center of the piston. We'll look at this much more closely later.
We have now passed through overlap. The exhaust valve has closed just after the piston started down and the intake valve is opening very quickly. This is called the intake stroke (figure 3), where the engine "breathes" and fills itself with
another charge of fresh air/fuel mixture. The intake valve reaches its maximum lift at some defined point (usually about 106 degrees) after top dead center. This is called the intake centerline, which refers to where the cam has been installed in the engine in relation to the crankshaft. This is commonly called "degreeing". We will talk about this later also.
The piston again goes all the way to the bottom and as it starts up, the intake valve is rushing towards the seat. The closing point of the intake valve will determine where the cylinder actually begins to build pressure, as we are now into the
compression stroke (figure 4). When the mixture has all been taken in and the valves are both closed, the piston begins to compress the mixture. This is where the engine can really build some power. Then, just prior to the top, the spark plug
fires and we are ready to start all over again.
The engine cycle we have just observed is typical of all four- stroke engines. There are several things we have not discussed, such as lift, duration, opening and closing points, overlap, intake centerline and lobe separation angle. If you will refer to the valve timing diagram when we discuss these terms it might make things a lot easier to understand.
Old 10-23-2002 | 02:30 AM
FindMe
Pg 2
Most cams are rated by duration at some defined lift point. As slow as the valve opens and closes at the very beginning and end of its cycle, it would be impossible to find exactly where it begins to move. In the case illustrated, the rated
duration is at .006" tappet lift. In our plot, we use valve lift so we must multiply by the rocker arm ratio to find this lift. For example, .006" x 1.5 =.009". Instead of the original .006" tappet lift, we now use .009" valve lift. These opening and closing points are circled so that you can see them. If you count the number of degrees between these points you will arrive at the advertised duration, in this case 270 degrees of crank- shaft rotation. In this illustration this is the same for both the intake and the exhaust lobes, thus making this a single pattern cam. Some cam manufacturers rate their cams at .050"
lift. If we again multiply this by the rocker arm ratio, we get .075". we can mark the diagram and read the duration at .050" lift. This cam shows around 224 degrees, standard for this 270H cam. The lift is very simple to determine. You can
simply read it from the axis going up. This is the lift at the valve as we said earlier. Sometimes you will hear lift referred to as "lobe lift". This means the lift at the lobe or the valve lift divided by the rocker arm ratio. In this case, it would be .470" divided by 1.5 or .313" lobe lift. The lift is simply a straightforward measurement of the rise of the valve or lifter.
We touched on opening and closing points a little earlier, but now we want to consider them even further. We talked about when these points
occur, and how they are measured. As you can see in figure 1, the valve begins to move very slowly then picks up speed as it approaches the top.
It does the same closing, coming down quickly then slowing to a gentle stop. It's kind of like driving your car. If you were to go from 0 to 60 mph in a fraction of a second and stop instantly, you can imagine what that would do to the car, not to mention the driver. It would be much too severe for any valve train to endure. You would bend pushrods, wear out cams, break springs and rockers, and lose all dynamic design. The cam would not run to the desired RPM level as you would have all these parts running into each
other. As the valve approaches the seat, you also have to slow it down to keep the valve train from making any loud noises. If you slam the valve down onto the seat, you can expect some severe noise and a lot of worn and broken parts.So it is easy to see that you can only accelerate the valve a certain amount before you get into trouble. This is some-thing Competition Cams has learned over the years-how far you can safely push this point.
Looking a bit further at the timing points, the first one we see on the diagram is the exhaust opening point. We have all noticed the different sounds of performance cams, with the distinct lopes or rough idle. This occurs when the exhaust
valve opens earlier and lets the sound of combustion go out into the exhaust pipes. It may actually still be burning a little when it passes out of the engine, so this can be a very pronounced sound.
The next point on the graph is the intake opening. This begins the overlap phase, which is very critical to vacuum, throttle response, emissions and especially, gas mileage. The amount of overlap, or the area between the intake opening and the exhaust closing, and where it occurs, is one of the most critical points in the engine cycle. If the intake valve opens too early, it will push the new charge into the intake manifold. If it occurs too late, it will lean out the cylinder and greatly hinder the performance of the engine. If the exhaust valve closes too early it will trap some of the spent gases in the combustion chamber, and if it closes too late it will over-scavenge the chamber; taking out too much of the charge, again creating an artificially lean condition. If the overlap phase occurs too early, it will create an overly rich condition in the exhaust port, severely hurting the gas mileage. So, as you can see, everything about overlap is critical to the performance of the
engine.
The last point in the cycle is the intake closing. This occurs slightly after Bottom Dead Center, and the quicker it closes,the more cylinder pressure the engine will develop. You have to be very careful, however, to make sure that you hold the
valve open long enough to properly fill the chamber, but close it soon enough to yield maxi mum cylinder pressure. This is a very tricky point in the cycle of the camshaft.
The last thing we will discuss is the difference between intake centerline and lobe separation angle. These two terms are often confused. Even though they have very similar names, they are very different and control different events in the
engine. Lobe separation angle is simply what it says. It is the number of degrees separating the peak lift point of the exhaust lobe and the peak point of the intake lobe. This is sometimes referred to as the "lobe center" of the cam, but we prefer to call it the lobe separation angle. This can only be changed when the cam is ground. It makes no difference how you degree the cam in the engine, the lobe separation angle is ground into the cam. The intake centerline, on the other
hand, is the position of the centerline, or peak lift point, of the intake lobe in relation to top dead center of the piston. This can be changed by "degreeing" the cam into the engine. Figure 1 shows a normal 270 degree cam. It has a lobe
separation of 110°. We show it installed in the engine 4° advanced, or at 106° intake centerline. The light grey curves show the same camshaft installed an additional four degrees advanced, or at 102 degrees intake centerline. You can see how much earlier overlap is taking place and how the intake valve is open a great deal before the piston starts down. This is usually considered as a way to increase bottom end power, but as you can see there is much of the charge pushed out the exhaust, making a less efficient engine. There is a recommended intake centerline installation point on each cam card, and it is important to install the cam at this point. As far as the mechanics of cam degreeing, Competition Cams has produced a simple, comprehensive video (part #190) that will take you step by step through the process.
On these pages we have discussed theory but the video will show you how to actually get the job done. Competition Cams has put a great deal of effort into the design and engineering of our camshafts. All of these points were considered
in each and every cam listed in this catalog What we intend to do here is show that camshaft design is not some "black art" but, rather, a series of decisions and compromises based on the exact application of the cam. Only our many years of experi ence can say whether a certain combination of lobes will work, so you should trust the judgement of those who have engineered these combinations. If you have any other questions, the Competition Cams Technical Staff can be reached at 1-800-999-0853 and will be glad to answer them for you.
sorry for the sloppy cutNpaste... courtesy of Competition Cams, the baddest camshafts on the face of the earth...
Old 10-23-2002 | 06:29 PM
Vinny P's Avatar
I hate the winter!!
As usual, another great job from " FindMe"
Vinny P is offline
PhantomChaos
05-16-2008 06:23 PM
BDavis1819
Wanted
4
03-30-2008 08:15 PM
OPA
1
05-01-2003 03:43 AM
jrocket
11-15-2002 07:52 AM
pb
02-26-2002 05:16 PM
