350 meg not performing up to par ? >
Old 04-29-2018 | 11:19 PM
Default 350 meg not performing up to par ?
I have a 21 foot advantage 21 SRBR Just read did the top end on my small block 355
AFR heads 180cc
edelbrock rpm air gap
scorpion roller rockers 1.5
x4270hr cam
brand new Edelbrock 1409 600 CFM carburetor
msd ready to run distributor Mechanical Advance set to 32°
bravo one drive
Bravo one prop 22p
Max out at 53mph @ 4300rpm will not go higher than 4300rpm
it just doesn’t seem right and I can’t figure out what’s wrong runs perfect
any suggestions on what I could be
hotshot537 is offline
Old 04-30-2018 | 05:13 AM
Ayuh,.... Ya need a smaller pitch prop to get the rpms up,....
Bondo is offline
Old 04-30-2018 | 10:12 AM
What was speed and rpm before?
30ftpanther is offline
Old 04-30-2018 | 11:05 AM
stock 350 with blown head gasket 14 x19p four blade offshore prop 50mph @ 5000rpm
Old 04-30-2018 | 11:19 AM
BUP
battery switch mounted to floor - I would move that to help keep exposed terminals from forming corrosion. And if its mounted on top of carpet - carpet stays wet plus dry carpet - a fire hazard waiting to happen. Just wanted to let you know. Not picking on you but safety is important as well.
BUP is offline
Old 04-30-2018 | 11:47 AM
It’s not mounted at all It screwsto the side of the engine cover when the engine covers installed and is approximately about 1 foot above the floor
Old 04-30-2018 | 05:16 PM
Have you tried the 14x19p prop AFTER the top end work?
Old 04-30-2018 | 06:39 PM
You added a blade and went up about 2.5 in the pitch. You need to try a smaller prop.
underpsi68 is offline
Old 04-30-2018 | 06:57 PM
Try a 21p Mirage Plus prop. with that setup.
94sylvan is offline
Old 04-30-2018 | 07:45 PM
yep, this will give you an idea of how much power you have gained. With that setup you want to spin at minimum 5000 rpms.
Ryan00TJ is offline
