496ho Ignition Troubleshooting
I have a 35 Fountain Executioner, while winterizing last year my friend held the key while the boat was running. Now the starter is not getting power. I jumped the starter solenoid and validated starter is good, checked the 90 amp fuse on starter, pulled and tested starter solenoid. Looks like starter solenoid is not getting power. I checked the breaker near the switch but still no power. Is there another fuse i am missing?
There is a slave replay up by the PCM, don't know your serial number so unsure if you have 3 or 5 relays. One of them is the slave relay which energizes the starter solenoid. It will have a small and slightly larger Yellow/Red striped wires on it
Genuine Mercury & Mercruiser parts. PCM and Bracket
That is what I was discussing.
The Small Yellow/Red goes from the key, to the neutral safety switch in the throttle control and back to the slave relay. See if you have 12V when key is turned on the S terminal.
If you do, turn key and move the throttle a tad FOR/AFT and if it cranks then the neutral switch or adjustment is the issue. If it doesn't then might be the neutral switch on corroded contacts
