2 Arneson #8 Surface Drives!! Longshaft models with steering and trim Rams !! >
Old 05-11-2018 | 08:50 PM
Default 2 Arneson #8 Surface Drives!! Longshaft models with steering and trim Rams !!
2- Arneson ASD #8 Racing Surface Drives!! Straight models and long 50" models 2" shafts . Comes with steering and trim rams and tie bar . Large High end 4 blade props , trim pumps , steering helm . Shifter's , 7' drive shafts , oil tanks , and more !! Removed from a 40' Magnum that had 600hp Diesels in it . $19,500 takes it all 727-243-2219
40fasthawk is offline
Old 05-11-2018 | 11:56 PM
So by straight models, does that mean no drop boxes?
endeavour32 is offline
Old 05-12-2018 | 01:55 AM
These would be a good start to a build i have dreaming up
Match them up with some hopped up 60 Series Detroits like Johnson and Towers used to build.
Put everything in a 55 foot sport fishing type hull built out of Juniper and epoxy minus the bridge and tower. Just a mid bridge
i used to build boats for Paul Mann Sportfishing bosts are badazz
This would ve a whole new level,
tommymonza is offline
Old 05-12-2018 | 07:57 AM
What prop shaft spline count do they have and could you please post a couple pictures
kvogt is offline
Old 05-13-2018 | 08:44 AM
wouldn' these #8's be a bit light for that big of a boat? I would think 10's or 12's would be better suited....
delsol is offline
