Bravo TRS Sportmaster and parts >
Old 05-17-2018 | 07:43 AM
Sick Stinger's Avatar
Brotherhood #1
Default Bravo TRS Sportmaster and parts
I have a collection of bravo drives. I’d guess 15/16 of the .
5 TRS drives all RH 1000 each or all 3k
2 bravo tie bars 1 with saddles other is a clevis
5 TRS tie bars
2 bravo steering caps
box of back caps
box of top caps
many shafts
gears
associted parts
1 -2 sport master with prop shaft and carrier 1700
Sick Stinger is offline
Old 05-17-2018 | 09:13 AM
are the 2 finned caps in the center of the pic for B1 and do they have a hole drilled in them for a shower? if so i would be interrested. for sure. also on the bravo tie bar saddles. do they go on trailing and of the drive where the trim rams attach?
freekazoid is offline
Old 05-17-2018 | 09:43 AM
Brotherhood #1
Yes where thevrear trim pin goes
caps I do believe are drilled to take a fitting for a shower.
No fin innrear are std bravo
Old 05-17-2018 | 10:12 AM
can you pm me a total for the caps, tie bar with saddles, ropes and the anchor please shipped to 60051
Old 05-28-2018 | 10:40 AM
Either of the dual ram steering mounts IMCO? If so how much
25Orion is offline
Old 06-13-2018 | 09:53 PM
Default Sportmaster
Interested in the sportmaster -2 lower. Is this a 1" prop shaft or 1-1/4"? Also does it have LWP? Not too familiar with differences. How many hours on it? Any idea? Thanks Kevin (443)-618-7917
Kevin Zamostny is offline
Old 06-13-2018 | 09:54 PM
Default Sportmaster
Pics of sportmaster drive please
Old 06-18-2018 | 10:00 PM
Default Prop shaft
Do you have a 44-41630 prop shaft for a bravo?
88baja226sport is offline
Old 06-18-2018 | 10:21 PM
Do you have a good TRS lower case?
gofastboater is offline
Old 06-19-2018 | 05:57 AM
Brotherhood #1
I have a good 1 inch shaft in house and will have a couple 1.25 end of week
yes I have a good lower TRS
