Hit a snag in my build..need help asap >
Old 05-22-2018 | 02:46 PM
BBYSTWY's Avatar
Default Hit a snag in my build..need help asap
Just got word from the engine builder that my stock 525 sc valve covers...the blue aluminum ones will not fit on the dart iron eagle heads I have...They said the gasket surface on the valve covers doesn't line up to the head sealing surface...
What are the least expensive options I have here?? this is about the last piece of the puzzle and don't want to spend hundreds of dollars on valve covers if I don't have to....
thanks
BBYSTWY is offline
Old 05-22-2018 | 04:12 PM
Teague
575cat is offline
Old 05-22-2018 | 05:56 PM
never heard that one before.... I have heard height problems, drip nib interference etc, but never the base being different...
Call Dart?? they should know what fits if their heads are odd shaped
phragle is offline
Old 05-22-2018 | 06:14 PM
BBYSTWY's Avatar
Yea I guess there’s no flat casting on the inside/rocker side of the mounting bolts...that is where the gasket/o-ring sits on the Merc covers and I need some where the gaskets sits on the outside of the mounting bolts if that makes sense??
Would standard cheap covers off like ebay clear the exhaust?? I have cmi headers...over 200 bucks is a hard pill to swallow for valve covers lol
BBYSTWY is offline
Old 05-22-2018 | 11:01 PM
Run a regular gasket with a steel core on the head and keep the O ring gasket in the valve covers and put it on top of the other gasket.
Something like this https://www.summitracing.com/parts/f...make/chevrolet
Griff is offline
Old 05-23-2018 | 05:48 AM
BBYSTWY's Avatar
So basically just stack the gaskets?? Have you tried this?? I'm only asking so I don't spend the money on these gaskets to have it not work...I guess I could use the gaskets regardless on new covers if it doesn't work
BBYSTWY is offline
Old 05-23-2018 | 06:01 AM
Man, not to rain on your parade, but if your building a blower motor and stressing over the cost of valve cover gaskets, life is going to get ugly.
phragle is offline
Old 05-23-2018 | 06:09 AM
it works, I’ve done it a couple of times
JaayTeee is offline
Old 05-23-2018 | 06:13 AM
BBYSTWY's Avatar
I'm not stressing about it but would like to avoid unnecessary cost wherever possible...thanks for your input tho
Thanks Jay...I'll get them coming
BBYSTWY is offline
Old 05-23-2018 | 07:10 AM
cigrocket's Avatar
This works, many have done this for years.
cigrocket is offline
